Pixelling on BBC via Netgem box,
Pam54
Message 2 of 2
Even with an aerial booster we get pixelling on bbc channels. Tried aerial direct to TV and all OK. New Netgen box seems be a pronlem
1 REPLY 1
Message 1 of 2
Is it only BBC Channels that are pixelating, do you see this on any other channels ?
Can you remove the aerial from the Netgem box and retune, then connect the aerial and retune again and see if this changes anything.
