TALK TALK TV HUB APPS NOT AVAILABLE SHOWING ERROR CODE YVM4503
Overandout!
Message 3 of 3
TALK TALK TV HUB APPS NOT AVAILABLE SHOWING ERROR CODE YVM4503 HAVE DONE ALL THE NECESSARY TURNING OFF ETC AND SWITCHING BACK ON STILL NOT AVAILABLE
Message 1 of 3
Do you have an aerial connected to the TV HUB with a good signal ?
Message 2 of 3
Please do not SHOUT, as use of capitals is seen as poor on forums.
Thank you.
The solutions for YVM4503 is the same as YVM503, so can you please try the steps outlined here.
https://support.youview.com/youview-box/error-messages/fix-for-yvm503/
If this does not work, could you please try a factory reset. This can be found under settings. If this works you will need to sign back into the apps.
