TV HUB REMOTE
ARKAY
Newbie
Message 2 of 2
AFTER PRESSING  AND THEN THE UP ARROW , NOTHING HAPPENS . WILL NOT ALLOW ME TO GET TO SETTINGS
1 REPLY 1
Message 1 of 2
Power the box off at the mains for 2 minutes, then power back on. When loaded, press the home button then see if you can use the arrows to navigate to the settings cog.
