TV box not working for live TV
Snaxdu
Message 5 of 5
I am using box model UZW4054TTG and last week when trying to watch live TV on all channels to came up with the error weak signal.  It was a bit of a surprise as I had a new aerial fitted about 7-8 months ago, but I thought they may have fitted incorrectly and was going to contact them to take a look.  However, I thought I should check by plugging the aerial straight into the TV and when I did that it worked.  I plugged it back into the box and it didn't work.  I still had an old Talk Talk TV box and so I tried it with that and again it works.  I am assuming there is a fault with the new box, which we have had now for about 4 months.  Please let me know if there is anything I should try on the box to get it to work.  Cheers!
4 REPLIES 4
Message 1 of 5
Glad to hear the reset has helped.
JSnoxall
Message 2 of 5
Hiya,
Many thanks for the advice.  The factory reset fixed the problem thank you.  It is a TV Hub by the way.
Cheers!
Jon
Message 3 of 5
Follow the advice from fr8ys and let us know how you get on.
Message 4 of 5
Try a retune from the settings menu and if that doesn't work try a factory reset.
Which box do you have? The Netgem or TV Hub.
Let us know how you get on.
