Talk talk hub box
Daddy1956
Message 5 of 5
Please help
I'm unable to connect my new box have followed instructions and get to connect remote but it won't.
I need to figure out tge reasons Anyone.
4 REPLIES 4
Message 1 of 5
Also, read this article about pairing the remote :
TalkTalk Remote Control Guide - TalkTalk Help & Support
holding the Home button and OK button down can set the remote into pairing mode,
Message 2 of 5
Have a quick read through our help article : Setting up your TalkTalk TV Box - TalkTalk Help & Support
This will help you check the steps you have completed.
When pairing the remote, make sure you are about a metre away from the TV Box, the bluetooth signal is at a lower power level when pairing, so see if it will detect the remote.
Daddy1956
Message 3 of 5
All correct then I get a message to connect remote but nothing seems to allow me to do it
Message 4 of 5
Is the box connected direct to the TV via a HDMI Cable ?
Does the box have an aerial connected at the back ?
Do you have an ethernet cable attached from the router or are you trying to set up the box via wifi ?
Can you describe, at what point the set up process is failing, what is on the screen etc.
