Talktalk 4k box
Geordyboy1
Message 3 of 3
Got a new 4k box a few days ago and setup an has been ok till today 28 April. On both catch up and watching live through the box there is a breakup of picture and sound only intermittently but enough to spoil the watching.
Can I do a soft reset without losing setting up the apps and could it resolve the problem
Message 1 of 3
Also worth a reboot of the router to clear any Wi-Fi issues etc.
Message 2 of 3
Best way to try a soft reset is to turn off from the mains and then on again.
If that doesn't work a factory reset from the settings needs to be tried but as you are aware you will need to reset your apps
