Tv free view box has stopped working message YVM4302 no signal cannot use the television
18215
Message 6 of 6
Cannot get any programmes to work
5 REPLIES 5
Message 1 of 6
@Dirtbiker
Oh and have you followed the advice given to @18215
Message 2 of 6
@Dirtbiker
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
Please also state what box you have.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
Dirtbiker
Message 3 of 6
My tv has stopped working and is displaying fault code YVM4302
Message 4 of 6
Hi @18215
Do you need assistance ?  Have you got the box working ?
Message 5 of 6
You should be able to watch TV by plugging the aerial directly into the TV, providing your TV has a Freeview tuner
Regarding the box the following may help, but if it's the Hub the instructions differ
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new, non recordable, box.
Hope it works and please let us know how you get on.
