What is the USB port on the Talk Talk TV hub used for
Manami65
Message 3 of 3
What is the usb port on the TV hub used for
Message 1 of 3
You can attached an external keyboard or mouse to the port.  I've currently got a usb webcam connected to my TV HUB as I was testing video calling via google meet, and that works fine 🙂
Message 2 of 3
You can use a USB stick or Micro SD card (not supplied with your TV Hub) to play compatible media (for example photos and home videos) on your TV Hub.
This external storage cannot be used to download additional Apps from Google Play store. If you need additional storage for Apps, you'll need to uninstall apps you no longer use/want to free up space on the internal storage. Your TV Hub will guide you through this if you run out of storage.
This is from the TV hub help pages found here
https://community.talktalk.co.uk/t5/Articles/About-the-TalkTalk-TV-Hub/ta-p/2915720
