Youview box
Tony471
Message 3 of 3
I'm unable to record or play recordings, I understand the huawei box is no longer supported by talk talk therefore please cancel my tv subscription ,regards A.  Lord
Message 1 of 3
follow the advice from fr8ys, and if resetting the box fails, give our teams a call.
Message 2 of 3
You will need to phone to cancel your tv subscription as it cannot be done on the forum.
Ask for the Loyalty team.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Do this anyway even if the following works, which may help you recover your box, albeit in the short term as they are approaching end of life now.
Try a soft reset. To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn't work then try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings though
Hope it works.
