how do I get a new hand set. Batteries are OK
Wilmar123
Message 4 of 4
3 REPLIES 3
Message 1 of 4
Hi @Wilmar123
I see you have the TV HUB. Can you tell me what is wrong with the remote - have you replaced the batteries ?  Does the remote turn the unit on ?  Have you tried re -pairing the remote with the box ?
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
Message 2 of 4
How are you getting on?
Message 3 of 4
Which box do you have? Old YouView remotes are no longer available but can be sourced via eBay.
Have you though tried resetting the remote? Instructions can be found here.
