talktalk box
nickcarter48
Message 4 of 4
Last two weeks  - some recordings 'failed to record' - recordings freeze and pixelate - picture occasionally freezes so have to reset box - using remote to box running very slow - have re-set box with no gain ... router fine and fast ... Do I presume the talktalk box is now faulty? ...
3 REPLIES 3
Message 1 of 4
TalkTalk have not provided these boxes for over 4 years and these are now unsupported.
you can try a Youview Maintenance Reset  but if that fails there is nothing more that can be done.
Message 2 of 4
Shows HUAWEI DN372T ... would that be it? ... when giving up on the recording can switch to iplayer and no problems ...
Message 3 of 4
What model box do you have ?
