Your Account
Unexpected charge for TalkTalk Engineer Visit
Brian291
Message 25 of 25
Following loss of broadband service I had a TalkTalk engineer visit on 10th March.  I understood that there would be a charge if problem was with in-home wiring etc.
I did not receive a written report of the engineer's findings but he told me verbally that, whilst his findings were inconclusive, he had made an adjustment to a "tight" connection in the back of the BT master socket.  He also suspected a possible router fault as the router took a much longer than expected time to sync.  He said that he would not replace the router at the time but TalkTalk would do so if problem recurred.  I was therefore not expecting a charge, however my latest bill shows a £50 charge for the visit.  Can someone explain this please?
(As of today my broadband download speed according to the router is just 4Mbps; it should be nearer 34Mbps.  I have logged another fault this morning; of course this may or may not be related to previous fault.)
24 REPLIES 24
Message 21 of 25
If the engineer did rewire the extension is not really relevant.  During earlier troubleshooting prior to the engineer's visit and conducted at the behest of TalkTalk, I was asked to unscrew and unplug the faceplate of the master socket (thus disconnecting all internal wiring) and plug directly into the test socket of the master socket.  This did not resolve the problem with the broadband.  Therefore the problem could not be due to the internal wiring.  I repeat my earlier statement that the engineer suspected a possible (intermittent?) fault with the router.  As I write this I still have a speed of only 4Mbps and await resolution of my latest fault report of 31st March.  I now regret renewing my contract last month.  Can this dispute of charge be escalated to a complaint?
Message 22 of 25
Hi Brian291.
I have checked the report.
The report states :Upgrade vdsl plate secure. Rewired extension inside.
Replaced rj11 cable. Reset hub back to factory settings.. Hub sync 38 mbps
Cx now receiving 35 mbps
The rewiring of the extension make this a chargeable visit as this is internal wiring.
Its a valid charge.
Message 23 of 25
Definitely a TalkTalk engineer
Divsec
Message 24 of 25
Hi @Brian291 your post has been escalated and you should hear soon. Was the engineer a Talktalk employee or open reach?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
