A return to Slow Broadband speeds following BTOpenreach visit
Plazticfish
Message 81 of 81
I experienced slow BB speeds a few weeks back and went through the torture of a chat session. This resulted in a BTO engineer visiting and changing the Master Socket to the latest. All was well for a few days and the speeds returned to 30/4 from 18/2.  Following issues with a Teams call I checked again last week and the speed had reduced to 18/2. I have raised a case online which is open.
As I explained to the agent during the chat session, I cannot use the DG8041W. Instead I have a DSL modem in Bridge mode with Unifi USG  feeding 2 x US-8-60 switches , 2 AP's and an IW-6. I have rebooted the system. I have checked cables and still no change. The Unifi console does not show any issue on my home network. There is no noise on the landline. I have not yet disconnected and waited 30mins to allow the DLM to reset. I can do this if required. The latest test today using your system shows a line speed of 22Mb down. See attached.
Please will you investigate.
Thank you.
80 REPLIES 80
Plazticfish
Message 61 of 81
Hi Debbie,
A contractor on behalf of BTO has called and tested the line. The indication from testing was that the problem lay outside. He investigated the external wall box wiring and then opened up the pit (on the edge of the property). There are two sets of cables to the property. The pair which was "live" showed lots of corrosion. He was able to connect the spare pair, but advised these too are corroded. His line test showed 25Mb down. Mine shows 22Mb. He did not force a reset of the DLM. I will wait for the connection to settle over the next few days to see if there is an improvement and contact you with an update. Roll on FTTP.
Thank you
Message 62 of 81
Morning @Plazticfish
Sorry for the delay.
We've arranged the engineer visit for 12/07 AM (8am - 1pm)
Plazticfish
Message 63 of 81
Hi Debbie,
I am available  8th, and 12th AM & PM
Thank you
Message 64 of 81
Hi @Plazticfish
Thank you. I've ran the test again and the same fault has been detected.
Please can you provide your availability for an engineer visit AM and PM?
Can you also confirm potential Engineer charges
Thanks again.
Plazticfish
Message 65 of 81
Hi Debbie, I have disconnected the TT router and am now using my normal setup. Happy for you to test.
Thank you
Message 66 of 81
Hi @Plazticfish
Would you like to connect the other router first to run another line test?
Plazticfish
Message 67 of 81
Hi Debbie,
I have tested with a Draytek DSL modem and the TT router. If both connections are showing the same fault then would you please arrange another BTOR visit.
Thank you
Message 68 of 81
Hi @Plazticfish
Thank you 🙂
The line test is detecting the same fault towards the property.
If you have tested with a different router then we will need to arrange an Openreach engineer visit to the property. Would you like us to arrange this visit?
Plazticfish
Message 69 of 81
OK will connect now
Message 70 of 81
Hi @Plazticfish
I can start the line test at half past 1 will this be ok?
Plazticfish
Message 71 of 81
Hi Debbie, Microfilter has arrived. I can connect TT router when you are ready.
Thank you
Message 72 of 81
Hi @Plazticfish
If you would like me to run the line test today then please can you let me know before 3pm?
Thank you.
Message 73 of 81
Plazticfish
Message 74 of 81
Hi Debbie, Let me find a micro filter and then I will confirm a suitable time.
Thank you
Message 75 of 81
Hi Plazticfish
If you could provide a 30 minute time frame for me to run the test (with router at the test socket) then I can arrange for the line test to be completed then.
Plazticfish
Message 76 of 81
My DSL modem is connected to a BT installed data extension in my study/office upstairs. The Type 4 master socket is downstairs. Since TT does not provide the ability to put the DG8041W into bridge mode, in order to be able to use my Unifi system with it, I have to use alternatives. I could plug the TT router into the master socket data port. I can't find a micro filter to allow me to plug into the test socket of the BT Mk4.
However, If I do this my home network system will be artwork and nothing else. Appreciate you need the TT router to run your diagnostics but I can only do this for a limited time as I am WFH. Can we arrange a suitable period to trial this. Perhaps you can PM me? Thank you.
Message 77 of 81
Hi @Plazticfish
The line test is detecting a potential fault towards the property.
Would it be possible to connect the router at the test socket so we can run a line test in this set up?
ltk007
Message 78 of 81
What can I say!
BB speed has gone from 39/8 to 12/2 and is now 25/2. Attempted to use the online "Check Connection" of TT only for it to report that a problem has been detected and to use the "chat" option to talk to an agent. Unfortunately, selecting this results in nothing happening!
Called technical support. The first call resulted in the agent commencing a line test, without warning, resulting in the line being disconnected. A second call later and after half an hour to the agent, I was informed that they are unable to access my account files and will call back within an hour when their systems are working. No call back received as expected.
BB speeds still an issue and no support from TT technical team. Great!
Plazticfish
Message 79 of 81
Hi Chris, no it is not. My DSL modem is connected to a BT Data extension, as my office is upstairs and the Master Socket downstairs. Thank you.
Chris-TalkTalk
Message 80 of 81
Hi Plazticfish,
Is your router currently connected to the test socket? - Your guide to main phone sockets - TalkTalk Help & Support
