on 16-01-2022 01:22 PM
Hi guys over the last days been getting a lot of disconnections ,done the pin hole re set swapped filter and cable no noise on land line switching it of for 30 mins seems a temp fix also tried a old faulty D Link router with no WiFi that appears to work so could be a Hub problem.
on 08-02-2022 08:34 AM
Hi kennyh1
Thanks for the update. I've re-checked the connection stats now and the line is in sync at 77.4mb.
Please can you power down the router for a full 30 minutes and then run another speed test?
on 08-02-2022 07:54 AM
Good morning Michelle Router been OK since Sunday no disconnects but Speed has took a big hit was getting high 60s on the Sagemcom Hub now it’s in the mid 30s every thing else seems fine phone is OK tried the 30 min off but no different online service check says no problems.
on 07-02-2022 07:47 AM
Thanks for the update and please let us know how you get on 🙂
on 06-02-2022 10:10 AM
morning Debbie new hub up and running OK up to now ill give it a test and if OK will send the Sagemcom Hub back thank you
on 04-02-2022 09:28 AM
Hi kennyh1
Thank you 🙂
on 04-02-2022 09:26 AM
Thanks Debbie will do
on 04-02-2022 08:43 AM
Hi kennyh1
Thanks for your reply 🙂
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
on 04-02-2022 08:30 AM
Morning Debbie yes please I’ll give that a try thank you.
on 04-02-2022 07:31 AM
Hi kennyh1
We can send a Huawei WIFI hub for testing, would you like me to arrange this?
on 03-02-2022 04:39 PM
Hi Karl new Sagemcom Hub hasn't cured the disconection problem done a service check on the line and all is fine, just got a red flashing light and only way to get it back is tun of for 30 mins every thing else is OK no noise on line, has a problem crept in with these Sagemcom Hubs? is there another type of Hub we could try?
on 19-01-2022 12:51 PM
Thats good news. Let me know if anything changes.
on 19-01-2022 12:38 PM
Hi Karl new Hub up and running no problems has yet thank you.
on 18-01-2022 08:46 AM
No Problem 🙂
on 17-01-2022 05:02 PM
thanks Karl will give it a go and let you know what happens
on 17-01-2022 02:40 PM
All tests are clear. A router is on the way for testing to rule this out.
on 17-01-2022 10:19 AM
forgot to say flashing red light on Hub and solid red
on 16-01-2022 09:19 PM
Hi there yes I’ve done that it all shows good no faults and no maintenance in the area and yes I’ve plugged the Hub into the test socket.
on 16-01-2022 05:59 PM
Hi @kennyh1,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow. If they think a replacement router is required they will be able to arrange that for you.
