Broadband and Phone Problems
TazMeister
Message 3 of 3
Hi All,
I am experiencing very low upload speeds - circa 3 Mbs and, with broadband intermittenlty cutting off as well as a crackly phone line.
This is after Openreach attended yesterday and said any issues had been fixed.
Any help appreciated.
TazMeister
Message 1 of 3
Hi TazMeister
One of my tests is picking up a copper line issue and this will need an engineer.
i'll drop you a PM to confirm some details
Skynet_TX
Message 2 of 3
Hi @TazMeister,
Do you know what Openreach were doing yesterday, was it something in your home, or out on the external network.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the phone & router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The staff on this community won't be around until Monday now, so you may get faster support by using the live chat or calling customer services on 0345 172 0088 over the weekend, however the staff here should respond to this topic early next week to help if you are still having issues.
