Broadband speed.
willro
Message 53 of 53
My broadband speed has gone down from 62.Mbps to 48.Mpbs, approx. this drop in speed has been constant for well over a month. I think this is a deliberate way for TalkTalk to cut costs. Is anyone else experiencing the same?
Regards William
52 REPLIES 52
Message 41 of 53
No unfortunately.
Message 42 of 53
Any luck? Do you have another router that you can test with?
Message 43 of 53
I have collected one or two micro-filters over the years but now I need one there is none to be found.
Message 44 of 53
Your would need to connect the cable from the router to the test socket with a micro-filter, there should have been one provided with the router
Message 45 of 53
According to the guide, it's a NTE 5C MK 4. on the socket it says Master socket 5C, Openreach Mk4.
When I remove the faceplate the socket behind is not the same as the cable from the router.
Message 46 of 53
Could you take a look at the master socket guide and let me know which type of master socket you have
Message 47 of 53
I don't think I do have a test socket after all. Sorry.
Message 48 of 53
Could you try connecting your router to the test socket and leave it there for at least 48 hours and we'll see if there's any improvement in disconnections and speed
Message 49 of 53
Yes I do have a test socket.
Message 50 of 53
OK thanks. Does your master socket have a test socket? - Your guide to main phone sockets - TalkTalk Help & Support
willro
Message 51 of 53
Thanks, Chris
Just one socket. telephone and router only.
Chris-TalkTalk
Message 52 of 53
Hi William,
Sorry to hear that your speed has dropped,
Line test is picking up a potential issue and showing a lot of disconnection which has caused the line management system (DLM) to reduce the connection speed to improve stability
How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) other than the router and one telephone?
