11 hours ago
Since last Monday my work VPN on my work laptop, Cisco anyconnect, has been blocked on my home network. I have tried it on multiple other networks across a range of isps along with hotspotting from my phone and had no issues. Contacted customer service 6 times and they have flat out told me there is nothing they can do.
Any help would be much appreciated, if not I will be having to change isp asap.
Cheers
10 hours ago
You're Welcome 🙂
10 hours ago
Hi Karl,
This now works thank you very much.
I'm slightly bewildered how you managed to fix it so fast when the clowns on the chat couldn't do it in about 8 hours of interaction. Maybe you should be getting their salary on top.
Many thanks again superb piece of work.
10 hours ago
I've also sent you a quick survey regarding our interaction.
10 hours ago
I've made a small change to the router settings, please can you retest.
