Can't Connect to Wotk VPN
AdamCastle
Message 13 of 13
I can't connect to my work VPN, and I can tell that the issue is to do with TalkTalk as it works fine when I hotspot from my phone.
AdamCastle
12 REPLIES 12
Message 1 of 13
Thanks for confirming 🙂
Message 2 of 13
Brilliant, that did the trick.
Thank you!
AdamCastle
Message 3 of 13
All done, router now showing version 158.
Message 4 of 13
update on its way, the router will drop offline for a couple of minutes while it updates.
Message 5 of 13
Yes please, will that mean the router goes offline? And do you have all of the details you need?
AdamCastle
Message 6 of 13
Would you like me to do it now, it will take up to 10 minutes to complete?
Message 7 of 13
That would be great, thank you
AdamCastle
Message 8 of 13
OK thanks. We can try updating your firmware, would you like to give this a try?
Message 9 of 13
Hi Chris, that's all done now
AdamCastle
Message 10 of 13
OK, could you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 11 of 13
Hi, I've just started working from this location and it hasn't worked yet. The router Device Ver is FAST 5364-3. T8
AdamCastle
Chris-TalkTalk
Message 12 of 13
Hi Adam,
Has it only just stopped working? Which router do you have?
