on 22-05-2022 01:41 PM
I have a talk talk Huawei router and Powerlink (?) extender.
I can pick up signal on a tablet from the extender but the two PCs that are next to the router will not connect wirelessly even though I have had no problems since it was installed (10 years ago?). I have connected one PC to the router using an ethernet cable and that is working ok. The signal strength is good 36 mBs .
I've done all the turning on and off and resetting the router and that makes no difference
Help would be appreciated
on 23-05-2022 02:50 PM
Hi Geoff
Thank you 🙂
on 23-05-2022 02:48 PM
Thanks Debbie
Will do
Geoff
on 23-05-2022 02:39 PM
Hi gowerboy1
I can now see the details in your Community Profile, thank you.
on 23-05-2022 02:35 PM
I've used two different machines and three browsers and they are all the same - first page OK then can't see button to go from second page to third page
on 23-05-2022 09:26 AM
Hi gowerboy1
Have you tried this using a different device or browser?
on 23-05-2022 09:18 AM
Hi Debbie
I can't get past the second screen on the profile update as I can't scroll down to the next button
on 23-05-2022 08:10 AM
Hi gowerboy1
Please let me know once your profile has been updated and I can send out the replacement router.
on 23-05-2022 08:03 AM
Thank you
on 23-05-2022 07:47 AM
Hi gowerboy1
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router for testing.
on 22-05-2022 10:01 PM
Perhaps the router needs swapping out in case it has a hardware fault on it. I'll ask TalkTalk to consider this for you.
on 22-05-2022 05:58 PM
The router is a talk talk Huawei HG633.
I left the machines for about three hours and thought that before I replied that I would check if the machine (a laptop) that had the ethernet cable would work without it - it has!!!!
I then checked the PC and this is now working wirelessly
Maybe the router was having a rest before it watched the football
I have no idea what had happened
on 22-05-2022 02:59 PM
2. What are the WiFi specifications of the WiFi network adapters in these two PCs?
3. Do you get any error messages when you fail to connect, if so please include a screenshot of them?
