on 21-01-2026 01:44 PM
Good afternoon,
Hope someone can help. After a few problems with my system which is a bit better, I'm now having trouble streaming programmes, from late afternoon and at night it's impossible. the same with my internet very slow. I did a speed test on my account, they said it was really slow and reset my router, sadly it has not solved the problem. I did a wi-fi analyser that scans what channel people are using, mainly channels 1,6,11 is there another channel i could use on 2.4 gh without losing connection as it's really busy and it was thought that's what's slowing everything down.
Thankyou
wJanet1
on 21-01-2026 03:14 PM
Great! @wJanet1 @KeithFrench will be able to look into this for you.
on 21-01-2026 03:13 PM
Thanks for your message, I am at home now.
wJanet1
on 21-01-2026 02:48 PM
Thank you so much @KeithFrench for your help.
on 21-01-2026 02:44 PM
Hi @wJanet1
I would be very happy to help you if you want it.
on 21-01-2026 02:22 PM
Thank you very much @Gliwmaeden2, would appreciate the help.
on 21-01-2026 02:17 PM
@wJanet1, you may need to work with @KeithFrench for a resolution. He has offered help in the past, such as here:
https://community.talktalk.co.uk/t5/Broadband/wi-fi-keeps-dropping-out/td-p/3137075#M883606
You may need to stick with his step by step support.
on 21-01-2026 01:52 PM
Hi there @wJanet1, I'm really sorry about the issue you are having. The streaming must be affected by the slow speeds which we are going to look into. Please confirm if you are currently at home. Thanks
