on 30-12-2022 05:02 PM
This router has been randomly rebooting almost since I first had it - and seems to be getting worse - up to several times per day.
I have tried official support channels, eventually new firmware was installed, which appeared to fix the problem for one day.
My line worked perfectly fine with BT router, never had issues like this - the DG8041W logs showed it had rebooted, but no cause (Tech support didn't even bother to check the logs).
I am getting to my wits end - I work quite a bit from home and am frequently losing connection to online meetings.
Google searches show this is a known problem with the DG8041W.
Are there any alternative broadband routers available?
on 03-01-2023 10:13 AM
No Problem 🙂
on 03-01-2023 10:10 AM
Thanks Karl,
As said in reply to Skynet its not always Kernel panic, the one a little whiole ago was something else (router rebooted, not just network down).
Not sure if relevant but I notice it seems to occur most often whenever there is a VPN service (Cisco Anyconnect) running to my work network.
Anyway fingers crossed 1.06 resolves it. Will update in due course.
on 03-01-2023 10:05 AM
Hi Skynet not all are kernel errors, this morning for example was:
2023-01-03 09:28:58 [Critical][Debug-Log] static:Receive DSL port down msg!
2023-01-03 09:28:59 [Debug][Debug-Log] static:[WAN_MNGT] ipv4 if set wan state down, wan Index=0x10201001.
2023-01-03 09:28:59 [Debug][Debug-Log] static:[L2M] xdsl channel 1 state change process. Status=down.
2023-01-03 09:30:42 [Critical][Debug-Log] static:Receive DSL port init msg!
2023-01-03 09:30:43 [Critical][Debug-Log] static:Receive DSL port trainning msg!
2023-01-03 09:31:06 [Critical][Debug-Log] static:Receive DSL port up msg!
2023-01-03 09:31:07 [Critical][Debug-Log] static:[dhcpc]get wan[wan3] ifindex[41] and Mac Addr[a0:1c:8d:63:51:9c] success!
2023-01-03 09:31:07 [Debug][Debug-Log] static:[L2M] xdsl channel 1 state change process. Status=up.
It is still V1.05T - it was a minor update allegedly to slightly different build
on 03-01-2023 10:00 AM
Firmware updated to V1.06t. This addresses the Kernal panic issue that can cause the drops in some circumstances. Try this and see if performance improves.
on 03-01-2023 09:56 AM
Thanks for updating the details. I'll update the firmware now, should take about 5 minutes.
on 03-01-2023 09:52 AM
Thanks Karl, just done.
Just had a random reboot 5 mins ago!
on 03-01-2023 08:11 AM
Hi Adrian
Can you please add your home phone number or account number to your 'Community Profile' so I can pick this up for you.
on 30-12-2022 06:22 PM
Hi @AdrianStannard,
The known issue that can cause the DG8041W to reboot only affects firmware version 1.05t, if you were on that version, and you were being affected by this problem, then you would see mentions of 'Kernel Panic' errors in the routers log. Firmware 1.06t resolves that problem.
What exactly do you see in the log, i.e. is the router actually just rebooting, or is it losing connection to the internet and having to reconnect ?
on 30-12-2022 05:34 PM
Talktalk does use another model.
You need to complete your community forum profile details for TT staff to identify your account, @AdrianStannard.
Please go via your avatar/name; settings; Personal Information. Add your Talktalk landline number/account number and SAVE CHANGES.
Staff will reply during the week, after the New Year Bank Holiday.
