on 02-09-2024 11:25 AM
In the last week my router has somehow 'switched off' the 2.4GHz wifi band on 4 occasions. On each occasion I log into the router's Advanced Configuration, WLAN, 2.4G Basic Network, to see the SSID Status as 'Disabled'. Re-checking the Enable SSID: box and hitting the Apply button fixes it.
Any ideas what may have suddenly caused this to start happening on this relatively old router that has previously worked fine?
Router details:
| Hardware Version: | I.1.01 |
| Software Version: | v1.05t |
on 06-09-2024 02:41 PM
Hi New Forest Giles
Ok, thank you for letting us know.
on 06-09-2024 02:39 PM
Funnily enough ,the router has behaved perfectly since I first posted on Monday.
If it fails again, I'll go for a factory reset the weekend after, when I will have sufficient time.
on 06-09-2024 07:45 AM
Hi New Forest Giles
How are you getting on?
on 02-09-2024 11:37 AM
If a factory reset will not re-enable the Wi-Fi channel, then a replacement router will have to be sent.
on 02-09-2024 11:34 AM
Nope, I was hoping to avoid this as I have a high degree of customisation which will take some time to re-configure.
However a factory reset is the logical first step...
on 02-09-2024 11:28 AM
Hi New Forest Giles
Have you tried factory resetting the router?
