DISABLE WIFI OPTIMISATION
Rugazi
Message 4 of 4
My router isn't using the WiFi channels I have set and WiFi works much better on the less congested channels, I believe from other posts on the forum it's a setting that needs to be turned off so could a member from the support team get that sorted for me and disable WiFi optimisation.
Thanks,
3 REPLIES 3
Message 1 of 4
Great, I'm glad to hear this 🙂
Message 2 of 4
Perfect 🙂 it seems to be working well now
Thanks,
Chris.
Message 3 of 4
Hi Chris
The WIFI optimisation has now been switched off.
Debbie 🙂
