Device reset. Cause: System reset due to kernel panic?
sirsimonuk
Message 11 of 11
now and then i get AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER message on my router log but also the router just restarts itself
as probable on my account the router is new less than 1 month, but what is causing this to happen
help welcome
10 REPLIES 10
Message 1 of 11
Hi @Markrg71
I've posted on your topic on the Community.
Message 2 of 11
Thanks @AllyM AllyM, much appreciated advice. Will do that. Thanks for the reply and have a great weekend.
AllyM
Message 3 of 11
@Markrg71 ,
There is a very good chance staff will update your router firmware if you start your own topic on the forum. To avoid confusion, they generally only reply to the OP of the thread and this one being over a year old will certainly not be in their current workflow any more anyway.
You should also update your forum profile with your personal details and your TalkTalk landline number in order that they are able to identify your account (don't post personal details on the thread though).
Also bear in mind that support on this forum is not "real time" and staff will likely not be back at work until after the holiday weekend so it may take a few days to get a reply.
Markrg71
Message 4 of 11
Hi folks,
So glad I've found this messageboard after lots of head scratching. I have the same same router with my contract and have been experiencing the same issue with on average of a once a day system reboot due to ',AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic'. Is there any chance of a firmware fix? Software version is running as v1.05t.
Many thanks in advance.
Message 5 of 11
Hi sirsimonuk
No problem. Please let us know how you get on.
Debbie 🙂
sirsimonuk
Message 6 of 11
if it was down to the firmware then should now be fine as only did it now n then sometimes weeks in-between
sirsimonuk
Message 7 of 11
thanks for sorting it , just seen firmware updated
Message 8 of 11
Hi sirsimonuk
Apologies for this.
I've made a change to the firmware version. Please can you retest and let us know how the connection compares.
sirsimonuk
Message 9 of 11
thanks for reply
Skynet_TX
Message 10 of 11
Hi @sirsimonuk,
This is a known issue that affects a small number of Huawei DG8041W routers running firmware version 1.05t, when the staff here are back next week they will be able to push firmware version 1.06t to your router, that will fix this issue for you.
Anonymous User
