on 05-11-2022 12:34 PM
I did a search through old posts and couldn't find anyone with a 5464 router - hence this post!
I'm a new customer with TalkTalk Business and have been given this hub:
TalkTalk Business Wi-Fi Hub 2
Hardware Version: FAST5464 2.00
Software Version: SG4K100136
GUI Version: 5.6.1
It's all connected and working, but (as expected) it doesn't handle bufferbloat properly and there are no QOS settings on the router. I'd like to use my own router with CAKE QoS.
I'd like to use the TalkTalk router as a modem because, for some reason, it is connecting with better Downstream and Upstream rates than my own Draytek Vigor 130 modem.
I can't see any setting for modem only or bridge mode on the router - is there a hidden menu option that I can set? I'd rather not have to configure a double NAT if at all possible.
Thanks for your help!
on 06-11-2022 01:19 PM
Have you connected one of the yellow ethernet sockets on the TT router to the WAN socket of your router?
on 06-11-2022 12:41 PM
Hi @KeithFrench
Thanks for the offer of help. I've now done the following.
Did I miss any config on the TalkTalk router? Appreciate any additional advice.
Thanks!
on 05-11-2022 06:56 PM
No it doesn't support modem mode as @ferguson said. However, it can easily be used as an initial router connected to the broadband and pass on an IP address to your own router. I can give full details on configuring it like this if required.
on 05-11-2022 12:49 PM
There isn't a modem only mode. As a TalkTalk Business customer I am afraid that this community cannot offer you support, other than in the most general way.
