I can't access my work VPN (Zscaler) using Talk Talk Broadband
jtisc
Message 21 of 21
Work VPN  :  ZSCALER
App version:  4.1.0.89
However I can access my work VPN using mobile data.
I can access my work VPN on other Wi-FI.
Until a few weeks ago when I got a new PC build I connected to work VPN without a problem. First with CheckPoint VPN and then AWS RAS VPN
My broadband has not changed.
My home access is fine.
The new thing appears to be the combination of Zscaler and my broadband.
On their own and with other components they work but together they cannot maintain a tunnel. 😞
jtisc
20 REPLIES 20
Message 1 of 21
Hi jtisc
Thanks for your reply 🙂
If you do experience any further issues then please let us know.
I have sent you a Private Message with a link to a short survey for the Community.
Message 2 of 21
Hi @Debbie-TalkTalk I am happy to accept the  router replacement as a solution, thank you all,
and I'll take the unchanging connection status as a non-impacting feature. 🙂
jtisc
Message 3 of 21
Hi jtisc
I've checked and the router has the latest firmware version.
I would suggest trying a pin hole reset for ten seconds. If you would prefer not to factory reset the router and it's not affecting you using the connection then I wouldn't worry too much.
Message 4 of 21
hi @Michelle-TalkTalk  yes I have re-set the router once, since unboxing, before I noticed this issue. I'd want to avoid doing it again and I have updated device names which takes time
I have powered off with the switch a few times and re-started the router using the admin interface with no change.
jtisc
Message 5 of 21
Good afternoon,
Thanks for confirming. Have you tried resetting the router and then retested this again?
Message 6 of 21
Yes tried the dashboard on 2 different browsers and even on another device. Same situation.
Reports that it is not connected to the internet even though it is.
jtisc
Message 7 of 21
Hi jtisc
I'm glad to hear that the VPN connection is now working ok.
Have you tried this in a different browser?
Message 8 of 21
Hi @Debbie-TalkTalk ,
I have now tested and happy to confirm I have a stable VPN connection, over Wi Fi with safety setting on.
From this perspective the query is resolved.
A curiosity is that the router dashboard software does not correctly report internet connected status. I see the following even right now when I am browsing and streaming etc.! It does not seem to impair service otherwise.
jtisc
Message 9 of 21
Message 10 of 21
Great thank you for confirming and please let us know how you get on.
Message 11 of 21
Thanks @Debbie-TalkTalk ,
Sagemcom FAST5364 received. Will update next week when I bring my kit back and work from from home.
jtisc
Message 12 of 21
Hi jtisc
Thanks for the Private Message.
Message 13 of 21
Hi jtisc
Please can you send me a Private Message to confirm the name on the account, I can then send you the replacement router.
Message 14 of 21
If you can arrange it I would be willing to try the 'Sagemcom Wi Fi hub' - thank you.
jtisc
Message 15 of 21
Hi jtisc
I think we should send you a Sagemcom WIFI hub, would you like me to arrange this?
jtisc
Message 16 of 21
FURTHER TESTING
Broadband normal mode with Protection ON
Temporary WIRED connection for testing but cannot be used to work as router is rooms away from work area.
case 00 | Wi Fi connection       | Protection ON        | Cannot maintain VPN
case 01 | Ethernet connection   | Protection ON        | Cannot maintain VPN
Broadband temporarily switched Scam protection OFF  in "My account":
case 10 | Wi Fi connection         | Protection OFF      | connects  VPN but temperamentally, have to re-start  a couple times
case 11 |  Ethernet connection  | Protection OFF      | appear s to maintain VPN
mobile data comparison only test case:
case 100 | Mobile data   |  no TT network features   | VPN connection is maintained
jtisc
Message 17 of 21
Hi @Debbie-TalkTalk
DLINK DSL-3782
Firmware Version: v1.10t
jtisc
Message 18 of 21
Hi jtisc
Please can you also add your TalkTalk landline number to your Community Profile?
Which make and model of router are you using?
jtisc
Message 19 of 21
Hi @Karl-TalkTalk , community profile updated with account.
jtisc
Message 20 of 21
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you.  Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
