Issues connecting to voice chat on Discord and other platforms
Diarogue
Message 9 of 9
I've tried to flush my DNS, use public DNS services from google, turn everything off and on again. I've also allowed every port to be available for Discord which is a range from 50000-65535. Nothing has worked. Connecting using a VPN or my mobile 4G works but using my internet does not allow me to join. I am only getting RTC Connecting.
8 REPLIES 8
Message 1 of 9
Thanks for confirming.
Diarogue
Message 2 of 9
Factory resetting fixed it thank you very much!
Message 3 of 9
Hi Diarogue
Our Products Team have asked if you can also factory reset the router using the pin hole reset for ten seconds?
Diarogue
Message 4 of 9
I do not get any other errors and this has been done
Message 5 of 9
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 9
Thanks for trying and I'm sorry to hear this. What happens when you try to connect, do you see any error messages? Are you using HomeSafe/Kidsafe?
Message 7 of 9
Hiya, I've just tried this and I'm still having the same issue
Message 8 of 9
Have you tried powering down the router for a full 30 minutes and then retested again as this will reset the current session?
