on 04-05-2022 06:35 PM
I have now tried several times to get a support agent to push firmware 1.06t to my router as I am experiencing repeated kernel panics. As a remote worker, this is causing me serious issues when the router reboots in the middle of a presentation.
I realise the agents in the chat are not technical specialists and are simply following a script, but I need this sorting.
(base) optimus@solstice downloads % tail hwontlog.txt
2022-05-04 17:28:47 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-05-04T16:28:47.189Z
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2022-05-04 17:32:12 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-05-04 17:32:12+00:00 DST], uptime is [68s].
(base) optimus@solstice downloads % cat hwontlog-2.txt| grep panic | wc -l
28
Router details:
Manufacturer:Huawei Technologies Co., Ltd;
ProductClass:DG8041W;
SerialNumber:2153035991QUL3010622;
IP:XX.XX.XXX.XXX;
HWVer:I.1.01;
SWVer:v1.05t;
on 06-05-2022 06:58 AM
Hi ufo_HG27JJ_1
Thank you 🙂
I've made a change to your firmware, please can you retest and let us know how the connection compares?
on 05-05-2022 03:14 PM
I leave the router on at all times so the firmware can be updated at any point.
on 05-05-2022 09:46 AM
Hi ufo_HG27JJ_1
Thank you.
Will it be ok if I make a change to your firmware this morning?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
on 05-05-2022 09:38 AM
Done.
on 05-05-2022 06:35 AM
Hi ufo_HG27JJ_1
Please can you add your TalkTalk landline number to your Community Profile, I can then take a look at this for you.
04-05-2022 09:17 PM - edited 04-05-2022 09:30 PM
I do hope so as I've now had yet another kernel panic which makes 6 times today
*Edit* Make that 7 times today.
on 04-05-2022 06:48 PM
The team here should be able to sort this out for you, hopefully within the next day or so.
