Patchy connection
Divsec
Message 28 of 28
Hi I would be most grateful if you could check out my line and router. I've been experiencing dropped and slow connections, no service etc. Even alexa losing connection with audible books!
I've changed to this router and things seem better but would appreciate a quick line and firmware checkup, please.
D
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
27 REPLIES 27
Message 21 of 28
Hi @Debbie-TalkTalk it's very kind of you, yes please. Sadly I think you will find the kit is doing the best it can and third party kit is needed for better.
Message 22 of 28
Hi D
Do you want me to take a look at the speeds for you?
Message 23 of 28
Hi @Debbie-TalkTalk thank you for checking,  yes internal WiFi speeds dropped a bit but massively more reliable. So all good enough here. Thanks for your time
D
Message 24 of 28
Hi Divsec
I'm sorry to hear you've experienced issues with the connection 😞
The line tests are clear - No faults detected and the router has the latest FW version.
Is everything working ok now you've swapped the router?
Message 25 of 28
Apologies, thought as much, but always best to mention.  🙂
Divsec
Message 26 of 28
Hi @ferguson oh very yes. On my third router but I think I've sorted it.
It was behaving like a dns resolution issue, I just now would appreciate a quick check on the 2 things I can't do myself, firmware and line.
D
Message 27 of 28
Sorry to see this bud. I take it have you have tried the usual checks yourself i.e. noise on the line, test socket etc?
