Recent broadband outage caused problem in My Account - not fixed a fortnight later
hawaye
Chat Champion
Message 11 of 11
On 30/07/23 I experienced a broadband outage which affected both numbers, *064 and *964. I reported the fault on Whatsapp and the outage was fixed very quickly. Unfortunately, seemingly the fault caused a problem in My Account, resulting in me being unable to do a speed check on my second number, *964. I attach a screenshot of the message.  Despite aiming for a fix within 3 days, TalkTalk have had this problem for a fortnight and any attempt to reopen the original Whatsapp chat have failed. And I'm expected to renew my contract with TalkTalk as the service on the second number gradually deteriorates. Can anyone help please?
Edit: screenshot removed.
hawaye Mornington Crecent County Champion 1975, 1976, 1978
10 REPLIES 10
Message 1 of 11
They may have given a goodwill discount for the issue with my account however this would not be given each month as this does not affect the working services, but is informational only.
Message 2 of 11
Thanks Karl. A test using Sam Knows requires that I visit the property to do first-line support for Internet problems. In most cases this is not possible for me. Post 6 explains why I need remote access. If your team can't restore the facility that existed before 30/07/23, I can't see us continuing a relationship that has existed since the Tiscali era. Please ensure that the refund that I was paid in July for the breakdown of remote access continues on a monthly basis. Thank you.
Message 3 of 11
This is still with the team for investigation, I'll chase them today to see if there are any updates.
In the meantime, you can use alternative speed test sites such as Sam Knows Speedtest
hawaye
Chat Champion
Message 4 of 11
Any progress on this fault please? We are now into week 6 and the feature that was present in Myaccount is still not working and my patience is wearing thin.
Message 5 of 11
I've reached out to the product owners regarding this, to see if they can see what is causing this.
hawaye
Chat Champion
Message 6 of 11
Hi Michelle,
No change as per attached screenshot at 10:45 am this morning
Message 7 of 11
I'm sorry for the delay. Is this still happening since your last post?
hawaye
Chat Champion
Message 8 of 11
Hi Karl,
Sorry for the long post, but let me explain why I need MyAccount working.
The line 2 number I have quoted as *964 is inside a holiday rental house. The occupants change weekly so there is no residual knowledge base for users at the rental. The reason for needing access to Internet performance remotely, and other details, from my mobile or office is that I am, among other caretaker duties, first-line support for the rental's Internet.  Today's use of SamKnows involved a short walk through the rain to WiFi range of the router and running it on my mobile, and a return walk in the rain.  During guest occupation or my own holidays, I don't have easy access to make a connection to the number *964 without online access.  In the past, I have used MyAccount to diagnose accidental disconnection of the router, deliberate reset of the router, and breakage of the copper between rental and exchange without being present at or near the rental.  Mobile signal strength is very poor on all networks at this location so guests have little chance of remaining connected using mobile data.  I hope this explains why I need MyAccount working properly, including reporting the correct make and software version of the router.
To answer your question, speed is 45.1 down, 20.7 up and 21.5 latency according to the link you have posted. The issue is not the speed at the moment, it's the ability to fault-find remotely, at any time, which MyAccount used to do nicely. You may say that I can diagnose router problems remotely by using a line check, but I believe this to be faulty also. Certainly MyAccount reports the wrong make of router at *964.
Message 9 of 11
we have seen this issue previously with the speed test and have flagged this for investigation. Tests on your line are clear and sync speed is at 65.8mb with the DLM profile set at 80/20.
What speeds do you see via Sam Knows Speedtest
Divsec
Message 10 of 11
Hi @hawaye your post has been escalated and you should hear soon could I suggest you remove the attachment which has detail you might prefer to keep private?
