Router Changing Wifi channel
sirsimonuk
Message 8 of 8
often i would find my router changes my WiFi channel , then my devices can no longer connect to it, unless i log in via the pc and swap it back , can something be done about this to stop it
Doing it?
7 REPLIES 7
Message 1 of 8
Hi sirsimonuk
sirsimonuk
Message 2 of 8
that would be wonderful please Debbie , I'm sure i did reply earlier but its not here so pass what happened ?
this router is old ,even looks it often it would loose connections in the past shame really as i love it overall works better than ones that you used before
Message 3 of 8
Hi sirsimonuk
The WIFI optimisation is still showing as switched off so this isn't changing the channel.
Would you like me to send a Huawei WIFI hub for testing to see how the connection compares?
sirsimonuk
Message 4 of 8
well it is still doing it keeps changing my band 1 channel from what i put it as to channel 10 where my devices loose the connection so i then have top turn on pc to change it back again even at 11.30pm at night
Message 5 of 8
Hi sirsimonuk
Apologies for this.
The WIFI optimisation has now been switched off.
sirsimonuk
Message 6 of 8
thats the one, Fast 5364 router
Skynet_TX
Message 7 of 8
Hi @sirsimonuk,
Do you have the Sagemcom Wi-Fi Hub ?, if so this router has a feature called 'Wi-Fi Optimisation' that can cause this to happen, the staff here can switch off the Wi-Fi Optimisation for you if you want them to, this would then mean the router would stay on whatever channel you manually set. But this only applies to the Sagemcom Wi-Fi Hub.
Some of the staff here on the community will be back tomorrow.
Anonymous User
