Router - Firmware updates needed
CallumRanger
Message 5 of 5
I work for New Forest District Council.
There is currently an issue where I am unable to connect to our security system (which allows me to work from home). Our IT department have identified that this is linked to the service provider TalkTalk who are actively blocking the ability for staff to work from home via a secure connection.
I understand from previous experiences that my router needs firmware updates and to address it here in this post forum.
I am currently using my mobile as a hotspot which isn't ideal as it drains my battery and data.
4 REPLIES 4
Message 1 of 5
Hi CallumRanger
Please can you try powering down the router for a full 30 minutes and then test the VPN connection again once the router has been switched back on?
Message 2 of 5
Hi Karl,
When I press connect it takes around 20 seconds and then displays a DNS error. I have spoke to my work IT and said that because I can tether my work phone as a hotspot using mobile data and connect to the VPN but can't connect to the VPN using my TalkTalk broadband it's the ISP.
Hope this helpsCallum
CallumRanger
Message 3 of 5
Hi Karl,
Hope this helps
Message 4 of 5
Hi Callum
I'm showing your router already has the correct firmware for VPN, version 2829t.
What happens when you try to connect to your VPN connection ?
