Sagecom fast 266 booster not connecting to wifi
JudeP56
Message 29 of 29
Start up procedure goes as normal, when activating WPS it just doesn't connect and times out
Mr Jude Player
28 REPLIES 28
Message 1 of 29
Please let us know how you get on 🙂
JudeP56
Message 2 of 29
Thank you for arranging another one to be sent out it is much appreciated, and thank you to everyone else on the thread who has helped me out with this issue it's been great to see so many people that are so knowledgeable and helpful!
Mr Jude Player
Message 3 of 29
Hi Jude,
A replacement is on the way now.
JudeP56
Message 4 of 29
Hi Karl, I have added my address to my private notes, I can attempt to find out my dad's account number when I'm back from work later on if its still needed.
Mr Jude Player
Message 5 of 29
Flashing red & WiFi light flashing white shows that the WPS process has started.
The middle light flashes green & the WiFi is solid white shows that the WPS connection is in progress.
Yours probably never goes green, because the 266 cannot detect any nearby router in WPS mode. I said before that this could be the 266 but could equally be the 5364 router. Have you tried a pin reset on the router to see if that makes any difference?
Message 6 of 29
Hi Jude
Add your account number to your 'Community Profile'  or full address to your private notes section of your profile and I can send a replacement booster to you.
JudeP56
Message 7 of 29
Honestly I don't actually know what my landline number is, we haven't had the landline phone plugged in for years now. I can provide other details of address and my dad's account if need be?
Mr Jude Player
JudeP56
Message 8 of 29
Having a read of those instructions has made me notice that the central LED has not been flashing green, maybe the central LED flashing red signifies that something may have broken inside the booster?
Mr Jude Player
Message 9 of 29
Hi JudeP56
if you add your home phone number to your 'Community Profile' I can locate your details and send another booster for you.
Message 10 of 29
The lights on the 266 at this point are quite helpful:-
https://community.talktalk.co.uk/t5/Articles/Setting-up-and-positioning-your-Wi-Fi-Booster/ta-p/2920...
Just expand the Lights Guide section at the bottom.
It is a shame that the amber & red lights can easily be mistaken for each other as they are very similar.
Message 11 of 29
OK, was thinking more that the middle light should start flashing green. And WPS should be selected on the Booster only after the router starts flashing orange. As I said, just checking.
Message 12 of 29
HI @ferguson
It is always worthwhile checking for misoperation I totally agree. The fact that the Wi-Fi light is flashing white on the 266 indicates that the WPS process is not waiting to start but has started.
Message 13 of 29
Yes @KeithFrench, I know, was just wanting to check that no mis-steps had been made here, easily done if you don't get it quite right.
Message 14 of 29
Hi @ferguson
The instructions say to press WPS button on the router first & then press the button on the booster. That way works fine, except in this case, of course.
Message 15 of 29
Forgive me for just recapping. You mention that the Booster light flashes red. That indicates that it is ready to pair. At this point you should press and hold the WPS button on the Hub until it flashes orange. After that you should press the WPS button on the Booster briefly, it should then flash green for about 30 seconds or so before it connects and turns to solid green. Are you not getting to that stage with those precise steps, with both devices next to each other?
JudeP56
Message 16 of 29
Hi Chris, it would be much appreciated if you could, I've had a lot of issues with my WiFi coverage over the years and that booster had really sorted my WiFi out. How does one go about arranging a new booster?
Mr Jude Player
Message 17 of 29
OK thanks, would you like us to send another booster to test with?
Message 18 of 29
Hopefully, @Karl-TalkTalk will replace the WiFi Booster for you, it has to be one or the other.
JudeP56
Message 19 of 29
And yes, when attempting WPS I have the booster and router facing each other within half a metre of each other.
Mr Jude Player
JudeP56
Message 20 of 29
I have tries resetting the device a couple times since I've noticed it not working, have held down the button until all lights are showing and reset procedure has started, still didn't sort it unfortunately.
Mr Jude Player
