Slow speeds - When will fibre get here
richyrich6
Whizz Kid
Message 20 of 20
If have had issues for a long while now with slow speeds and dropping out.
The open reach guys say there is a cable issue somewhere but they dont know where, So my speed has dropped from 35 to 22MBS which is not what I pay for.
They also commented on the fact there was fibre cable rolled up under the road, So I guess it may be coming soon..
We have all been contacted recently by Airband to upgrade to fibre coming soon. Do I need to change to get proper speeds or is there a chance you guys will upgrade imminently..
Just would like to get grown up speeds in this day and age..
Many thanks
19 REPLIES 19
Message 1 of 20
I'm sorry to hear this. I can see that the sync speed hasn't increased as yet. I've included a Help Guide below which has more information.
Speak to a Person | Contact Us | TalkTalk Help & Support
Message 2 of 20
New router gives exactly the same speed results. See attached
How do I get hold of the loyalty team, Never easy to find how to contact talk talk
Thankyou
Message 3 of 20
It may be worth contacting our Loyalty Team directly as they will be able to confirm if Future Fibre (FTTP) is available to you and place an order if available. Please let us know how the router compares 🙂
richyrich6
Whizz Kid
Message 4 of 20
Fantastic, Thanks for your help.
I checked on FTTP availability, it says It is available, a shame nobody tells us, although I dont believe it as open reach says they need a road closure to connect it. which hasnt happened.
Any way thanks again
Message 5 of 20
Hi richyrich6
In regards to FTTP availability, there is an availability checker on this page Guide to Future Fibre and FTTP | TalkTalk
richyrich6
Whizz Kid
Message 6 of 20
OK Yes please happy to try anything..
How can i find out if fibre to the premis is imminent ?
Thankyou
Message 7 of 20
Hi richyrich6
It would be worth testing with a different router so this can be ruled out. If the router is faulty and causing errors or re connections then DLM wont increase the speed/profile.
Would you like me to send a router for testing?
richyrich6
Whizz Kid
Message 8 of 20
Hi Not tested with a new router but open reach tests only show 26mbs at the socket so shouldnt be a router issue ?
Thankyou
Message 9 of 20
I'm sorry to hear this. I've re-checked the connection stats/re-run the line test now which is still clear. Can I just confirm, have you recently tested with a different router?
richyrich6
Whizz Kid
Message 10 of 20
I come back to this thread as need to move forward with issues..
I Pay for 35mbs and was until recently getting over 30mbs
This has dropped to 24 (the minimum on my contract) when TalkTalk measure it, but in reality 23 at my laptop.
Talk Talk may be happy they are within contract minimums but I am not getting what I am used to and require to operate my home.
Open reach have spent a long while trying to sort it and believe there is a faulty cable so havent done anything about it.. At the same time Open reach were adding fibre infrastructure to the ductings and state it is in the road and due to be connected which would solve my problems..
I cannot find anyone who will confirm if and when fibre to the premis might happen.
I either need my cable mending or fibre to the premis to be connected.
I cannot continue with the minimum speed.
Please please can someone help or pass me to someone that can, It is pretty much impossible to find how to talk with someone at Talk Talk. so you are my last hope.
Message 11 of 20
All tests are clear currently.  Would you like to test another router to rule out any hardware issues ?
richyrich6
Whizz Kid
Message 12 of 20
How do i get hold of the sales team..
Please run tests by all means, but the ones I did say I have been at 24mbs all the time but was at 35 then 22 then 2 then 0.2 back to 22 today. something somewhere isnt right.
Thankyou
Message 13 of 20
Hi richyrich6
Would you like me to send a replacement router for testing first so we can rule this out?
richyrich6
Whizz Kid
Message 14 of 20
Today I have less than 2mbs.. All the support tests say I have 24mbs which I havent had for a month or 2 the tests also say I have 24 to my devices They all read < 2 even when connected through lan from router..
Maybe I need a new router or maybe the tests dont show actually what is happening...
I am getting quite cross now without the full speed I pay for which I was until recently.. Something has changed out there.
I stated before the engineers say fibre is in the road outside cant anyone tell me when it will be connected..
They know we have an issue as we have copper cable running over 1000 m across town to our nearest cab...
Please someone help
We have been sort of forced into the online world and cant operate without it
Message 15 of 20
Hi richyrich6,
it's really  the distance from your home to the street cabinet that affects your speed, the overall distance to exchange isn't really an issue as the cable from the exchange to the street cab is fibre. As the speed is still low with your router connected to the test socket we can arrange another engineer visit if you like?
richyrich6
Whizz Kid
Message 16 of 20
Yes I have done all tests available.. The open reach guy knows where he thinks the fault is but suggested i investigated if fttp was arriving soon as I am a very long way from the exchange and often get issues with speed
Message 17 of 20
I've run a test on the line which hasn't detected a fault. Can I just confirm, have we ever done any testing previously, such as the router connected directly at the test socket for at least 48hrs?
richyrich6
Whizz Kid
Message 18 of 20
Thanks for your reply. I would like my speed back where it was at 35, But the open reach guy couldnt sort it, as a cable fault.
I havent talked to sales but that is probably a good idea.. It is quite disappointing having quite a good speed only for it to get worse.. I believe the only way to get better speed is through fibre, Wherever I get it from.
Many thanks
Message 19 of 20
I'm sorry to hear this. Would you like us to take a look at your current speeds for you? Have you been in contact with our Sales Team directly as they may be able to advise when FTTP will become available?
