on 13-06-2022 09:45 AM
Hi SUPPORT,
While I was looking into the log to see what happen to the Internet. I noticed the TalkTalk Wi-Fi Hub 2 NTP is not able to sync time correctly. I have try change the NTP server to google is not working either, I can confirm by pinging the google and your talktalk NTP servers both are able to ping. but your router is not functioning properly.
on 20-06-2022 09:12 AM
Hi Micmic
I have posted on your other topic on the Community.
on 20-06-2022 09:11 AM
Hi support NTP sync has failed again. after internet dropped last night. all the log data time is incorrect.
on 14-06-2022 09:12 AM
Brilliant, thanks for confirming 🙂
on 14-06-2022 09:11 AM
fantastic. NTP is working now.
on 14-06-2022 08:04 AM
Our team have advised that this should now be working. Would you mind retesting please.
on 13-06-2022 11:53 AM
The team are just looking at this now.
on 13-06-2022 11:04 AM
@Anonymous has taken it on board.
13-06-2022 10:58 AM - edited 13-06-2022 11:00 AM
Hi Keith, the original NTP setting wasn't able to sync the time that's why I changed the NTP server. I did a ping on the NTP server they are fine. I also factory reset the router too. None of these help
on 13-06-2022 10:31 AM
Thanks, I've also asked our Products Team to take a look.
on 13-06-2022 10:22 AM
I do not have the hub 2, but I have never had an issue in respect of NTP with the first Sagemcom, set as default like this:-
What happens if you use these NTP servers?
If it still does not work, and neither does a factory default, then I will draw this to the attention of the TalkTalk products team.
