on 18-01-2022 11:01 AM
Recently VPNs have not been connecting from home using any Windows device. I understand there is an issue with Sagemcom routers with firmware SG4K100130 (which is what mine is). Please can I have a replacement router sent out? I work from home doing technical support for schools across my county and I need to be able to test their VPN connections frequently which I am no longer able to do.
This is using inbuilt Windows 10 VPN functionality, connecting over PPTP VPNs.
Thanks and Regards
on 09-05-2022 03:32 PM
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 09-05-2022 03:23 PM
Hi Karl, I have had the same issue since last winter. How did you resolve it pls?
Kind regards,
on 09-05-2022 03:15 PM
Hi, I face the same issues since winter. How did you resolve your problem pls?
Kind regards,
g
on 18-01-2022 01:51 PM
You're Welcome 🙂
on 18-01-2022 01:50 PM
Hello Karl,
All working now, thank you! I really appreciate the speedy fix.
Have a good day
on 18-01-2022 01:47 PM
I've made a change, can you reboot the router and test your VPN connection and tell me if it works.
