VPN WhatsApp and Firewall Issues
ggttjm
Message 9 of 9
Sagecom WiFi hub. Firmware ending in 136
Adding my query/comment to the growing pile of similar on here
Since Monday 2 May work VPN does not connect, nor Bosch EasyControl thermostat. WhatsApp “thinks about it” before displaying messages, and similar with emails
Everything works fine if I reduce firewall security settings to Medium, which I’m not keen to do on a permanent basis.
Any fix for this in sight, or do I need a firmware rollback?
8 REPLIES 8
Message 1 of 9
Glad our team were able to help.
Message 2 of 9
All working properly now, thank you for fixing this so quickly
Message 3 of 9
Hi ggttjm
The firmware has now been updated.
Please let us know how the connection compares.
Debbie 🙂
Message 4 of 9
Hi ggttjm
Thank you 🙂 I will start the update around 1pm and I will post back on this thread to confirm once the firmware has been updated.
Message 5 of 9
Hi, thanks for your reply. It’s Sophos:
Sophos Connect service 2.1. 20.0309
strongSwan service 5.8.0
OpenVPN service 2.5.0.0
Message 6 of 9
Thanks for looking at this so quickly Debbie.
Anytime between 1-2pm today is fine
Message 7 of 9
Hi ggttjm
I will need to make a change to your firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes.
Skynet_TX
Message 8 of 9
Hi @ggttjm,
The support team may be able to make some changes to resolve the VPN issues, not sure if that will help with the other issues though.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
The support team will hopefully be able to reply tomorrow to help.
