on 16-05-2022 09:12 PM
Hi, like many others I'm having issues connecting to my work VPN. This has worked fine for many years. Please could you advise what can be done?
on 18-05-2022 05:58 AM
Hi EmsJL
That's great, thanks for letting us know.
on 17-05-2022 10:44 PM
@jrs270575, I've just posted in the topic you started, the staff here will provide more help in that topic
on 17-05-2022 09:40 PM
Hi I’m having the exact same problem,
please can someone help ?
on 17-05-2022 05:52 PM
Thanks Karl. This is now working.
on 17-05-2022 06:56 AM
I've made a change to your router, try the VPN connection this morning and let me know.
on 16-05-2022 10:01 PM
Hi, thanks for the reponses. Yes I have the Sagemcom wi-fi hub and the VPN software is built in. Hopefully this can be resolved quite quickly.
on 16-05-2022 09:38 PM
Hi @EmsJL,
If you have the Sagemcom Wi-Fi Hub then this will probably have been caused by the firmware upgrading to a new version.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
The support team here will be able to help, if you do have the Sagemcom they will probably be able to fix it by changing some router settings or changing the firmware, they will hopefully be able to reply tomorrow.
