VPN help
Graham57
Message 7 of 7
My VPN connection into work no longer works, I believe something to do with the router  (SG4K100130) please help as it is causing work issues
6 REPLIES 6
Message 1 of 7
Hi Graham
That's great, thanks for letting us know 🙂
Message 2 of 7
Hi Michelle,
it works perfectly, thank you for getting this sorted for me 🙏🏻
kind regards,
Graham
Message 3 of 7
I've made a change now, please let us know how the connection compares.
Message 4 of 7
Hi Debbie yes please do, it is available all day today and tomorrow,
thank you
Graham
Message 5 of 7
Hi Graham57
I can make a change to the firmware.
Will it be ok if I do this today? The router will reboot whilst I'm doing this update.
Skynet_TX
Message 6 of 7
Hi @Graham57,
What VPN software are you using (or is it the built in Windows 10/11 VPN) ?
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
