VPN no longer connecting
blackbeard
Message 13 of 13
Similar to other recent posts on here, as of yesterday my work VPNs are no longer connecting. They fail with error 806.
Can anyone offer any advice please?
12 REPLIES 12
Message 1 of 13
Excellent, thanks for confirming.
blackbeard
Message 2 of 13
Yes, that's working now! Thank you
Message 3 of 13
Hi @blackbeard
I've made a change to the router, can you try the VPN connection now.
blackbeard
Message 4 of 13
OK, thanks, I can give that a go.
Message 5 of 13
Hi @Jaz13
I'm sorry to hear this. Please can you create a new topic on the Community, we can then take a look at this for you.
Jaz13
Message 6 of 13
Hi there, I'm also getting the same issue.
Message 7 of 13
Hi blackbeard
Would you like me to send a Huawei WIFI hub for testing to see how the connection compares?
Jaz13
Message 8 of 13
Hi there, I'm getting same issue. Unable to connect to my work VPN.
blackbeard
Message 9 of 13
There's nothing in the Windows Update history since December so I don't think the VPN client has had an update recently
Message 10 of 13
Hi blackbeard
Thanks for confirming this.
Do you know if the VPN client has had a new update over the last couple of days?
blackbeard
Message 11 of 13
Just the built-in Windows 10 client
Message 12 of 13
I'm sorry to hear this. Can I just confirm which VPN client you are using please?
