VPN will not connect
Jb6789
Message 11 of 11
My work laptop will not connect. The IT dept have been through everything to identify the issue and we have excluded all other possibilities. They told me the issue was caused by an update to my router? They told me to contact Talktalk to ask for the firmware to be downgraded to allow the VPN to connect. Can a technician help with this please? Thanks
John Belcher
10 REPLIES 10
Message 1 of 11
Hi @Jb6789
I'm glad to hear that this is now working.
As ferguson has advised, this was related to an issue with router FW version 202. This will now be fully resolved in the next firmware coming very soon.
Message 2 of 11
Basically, there was a bug in the latest update that affected certain users and this has been rolled back for you. A newer, more stable firmware is expected to be released shortly.
Message 3 of 11
Its working now. The vpn has connected. I would love to know what you did that your colleagues failed to do over the past 3 weeks with hours wasted on webchat. They were adamant my work IT dept had to fix it. Thank you, I really appreciate you fixing this
John Belcher
Message 4 of 11
There was no change. I turned the router off and on again and now there is no connection on any devices. There is an orange flashing light on the router
John Belcher
Message 5 of 11
Hi @Jb6789
Thank you for updating your Community Profile.
I've made a change to your router firmware, please can you retest?
Jb6789
Message 6 of 11
I have updated the profile. It has now been almost 3 weeks since Ive been able to use my wifi with my work laptop. 3 lengthy webchats with Talktalk with no outcome. On Tuesday night after almost 1.5h I was told to contact my work IT dept even though I had explained the situation several times. I need the firmware to be downgraded asap.
John Belcher
Anonymous User
Message 7 of 11
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
Message 8 of 11
It is on the rear behind a pull up panel normally. I will guess that it is either a Sagemcom 5364 or 5464.
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
Jb6789
Message 9 of 11
Yes cisco any connect. Its a talktalk router, cant see a model on it
John Belcher
Message 10 of 11
What VPN client is this, is it Cisco AnyConnect? Which make/model of router do you have & what is its current firmware version (go to the router login page & it is shown at the bottom left of the page - no need to login)?
Anonymous User
