VPN working from home
Haylzx
Message 36 of 36
I am having issues connecting to the VPN to work from home. I have read other forums and been told its due to my router and i need a new one please help. I have tried live chat but this did not help at all.
35 REPLIES 35
Message 1 of 36
Hi Haylzx
I'm so glad to hear this, thanks for letting us know 🙂
Message 2 of 36
Hello all, i’m pleased to report its now working 😀 thank you very much for your help.
Message 3 of 36
OK, please let us know when you can.
Message 4 of 36
Hi Michelle, I haven't had a chance to test yet. Will be able to tonight once I finish work as having to work in office until all of this is resolved. And as you can imagine don't want to be testing work equipment on my days off.
Message 5 of 36
Can I just confirm, how are you getting on? Is this now working ok?
Message 6 of 36
Hi Haylzx
Thank you. Please can you retest and let us know if you are now able to connect to VPN?
Message 7 of 36
Yes
Message 8 of 36
Do you have the new router connected up now ?
Message 9 of 36
Hello it has bronze holes same as the other router i had?
Message 10 of 36
Hi Haylzx
Both WIFI hubs look similar.
Does the new router have black holes at the front or bronze holes?
Message 11 of 36
Yes i believe so a second one turned up but it looks exactly like the others is that correct?
Message 12 of 36
Hi Haylzx
Did you receive the Huawei WIFI hub?
Message 13 of 36
Hello Michelle, Still no luck this router doesn't work with my works vpn getting an error code 619
Message 14 of 36
No problem and please let us know how you get on 🙂
Message 15 of 36
Thank you debbie fingers crossed
Message 16 of 36
Hi Haylzx
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Message 17 of 36
Hello Michelle, no i havent tried one of them yet. If i could have one sent that would be great thank you
Message 18 of 36
I'm sorry to hear this. Just to confirm, have you ever tested with a Huawei Wifi Hub? If not then I think we should send one to test this.
Message 19 of 36
Hello Debbie, Just tried and still not working.
Message 20 of 36
Hi Haylzx
Please can you reboot the router and try and connect again?
