Wifi Down Again
CharlieMD1
Message 4 of 4
My wifi/internet keeps going down - really not sure what to do as have posted on the community a couple of times previously and it's always been fixed which I really appreciate however It's becoming a serious issue with WFH as I have to switch to my 4G Hotspot to take calls because the wifi is so unreliable.
Any help?
Charlie
3 REPLIES 3
Message 1 of 4
I've made a small adjustment to your connection and reset the dataport.
If you can check your socket to see if it does have a 'Test Socket' and test directly at this to rule out any internal issues.
Message 2 of 4
Hi Michelle,
My wifi is down again today, there's just an amber light on the router. I've had to switch the 4G as working from home but that's not a permanent solution.
I don't know if it's got a test socket or not.
Charlie
Message 3 of 4
I'm really sorry to hear this. I've run a test on the line now which is clear, however the connection does look unstable. Is there any noise on the voice service? Does your main socket also have a test socket please?
