Wifi connection keeps dropping and reconnecting
Veiled
Message 11 of 11
Hi everyone,
I am having some issues with my Wifi as it keeps on dropping and reconnecting atleast 10 times today. I have done speedtest on Talktalk and I am getting 3mbps while I am on Fibre 65 and used to get speeds over 55mbps.
I have raised a fault the reference number is below. The fault tracker page says we need to talk with you please contact our team.
Fault reference number
REP-12832474
I would appreciate if you can help me with the situation as it is not reliable for use.
Veiled
10 REPLIES 10
Message 1 of 11
Glad the speeds have returned to normal levels.
Message 2 of 11
Hi again Karl,
I have received the new router and did a speedtest on it. This seem to be working fine with no issues, the speeds are back to acceptable levels, I guess my old router was causing the issue after all these years it gave up.
I will observe but so far so good.
Thanks again.
Message 3 of 11
No Problem 🙂
Message 4 of 11
Thanks everyone. I will give it a go with the new wifi hub and see how that one goes.
Message 5 of 11
Hi Veiled
Line tests are clear, so no visible issues.
I've a new router on the way so this can be ruled out.
Message 6 of 11
I'll ask TalkTalk to deal with this on their return. There is a skeleton staff tomorrow, or it may not be until Tuesday.
Veiled
Message 7 of 11
Hi Keith,
The status turns orange beeps then orange/white and white again.
I have unplugged the master socket and reconnected have no disconnections today but my speeds is terrible 8mbps should be around 55mbps. I will wait for further replies.
Message 8 of 11
When this happens, what is the status of the light on the front of the router?
Veiled
Message 9 of 11
Thanks Skynet, let me try reach the live chat that you provided if not will give customer services a call.
Skynet_TX
Message 10 of 11
Hi @Veiled,
The Support Team on this community probably won't be around until Monday / Tuesday now, so you may get faster support by using the live chat or calling customer services on 0345 172 0088 over the weekend, however the Support Team here should respond to this topic early next week to help if you still need them.
