engineers charge
gordony
Message 3 of 3
I recently had a problem where talktalk router was not connecting with  permanent orange light ,My home system is  BT master 5C with bt extension socket 10 meters away in next room.
I reperted fault and went through online test with talkltalk agent going through line tests   including moving router to master socket with face plate removed  reseting router and full line tests by agent taking approximately 45 minutes  when the agent  arranged engineer visit  earliest  visit would be in 8 days.
As I was needing to send  and receive emails regarding my wifes hospital visits I loaned  a TP-link_7D01 router which connected immediately at remote bt socket and used this set up for the next 7 days removing the evening before Talktalk engineerwas due to visit ,I replaced the talktalk router which still only displayed orange light this remained overnight.
   I explained what I had carried out to enginneer and he then tested line with test phone at remote extension with this working normally , he then exchanged filters at master socket and extension socket power supply and cables, with router still not connecting, 30 minutes after he moved router to master socket  with cables dangling across door and across the floor but router still did not work, he then  removed the face plate and checked the connections of master socket he then connected router again and router orange light changed to white at this point he suggested to leave router here and connect to PC via wireless, He did not check to see if a signal was transmitting from wifi ,but just collected  all his tools and cables and left,
 I then disconnected router to re-arrange cables that where a trip hazzard reconnected to router into master socket with face plate still removed which but then router  was not again connecting with orange light displaying, this was only 5 minutes after he had left our home.
I called him back on the phone number he called us on to let us know he was a few minutes away, but I did not reeive a reply so I sent a message saying that router was not now connecting but never received a reply.
I then borrowed back TP-link_7D01 which connected straight away at BT remote socket,
After this I posted message on Talktalk forum to which I received a reply fronm customer service which arranged replacement router to be sent thias was received 2 days later and s been working since then with old router returned to talktalk in prepaid envelope.
BUT....
JUST RECEIVED MONTHLY BILL
PLUS £75 SERVICE CHARGE WHAT?
 Conntacted overseas call centre who I quoted all above but said charge will stand to which I objected to  they agreed to look into this but 2 days 19/11/24  later they offered 50% reduction
no way !
no charge
or I am off
gordony
Arne-TalkTalk
Message 1 of 3
Hi gordony
I can see that credits have been raised for the charge.
Gliwmaeden2
Message 2 of 3
If it was a Talktalk engineer and it was a fault with the router they are not supposed to be charging you, @gordony, whereas with Openreach it's not their equipment. So Openreach charges if there's no fault with the line (and as the line worked with the other router, there wasn't a fault with the service provided by Openreach).
Are you sure it was a Talktalk engineer? Not Openreach?
See the nuances of charging for these visits here:
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
Staff will be able to check which engineer it was, their notes on the visit etc. He may have recorded the problem as being with the extension wire / socket and being within the premises it is treated as being your property.
Hopefully he kept a record of  your attempt to contact him, but your own phone records should prove it too.
Staff on here frequently send out a router to test with BEFORE any engineer being sent out, precisely to avoid this scenario.
Unfortunately the agents on the phone / Chat don't seem to take the same approach.
Staff will be back on here during the day. Hopefully a positive outcome.
