internet dropping every half an hour
Starlightbeebright
Message 13 of 13
This has been going on since Friday. You have roughly a 2-3 hour wait on live chat, and they will tell you there arent any issues on your line. Then when you might be getting somewhere cut you off and you are right back where you started. This is not currently fit for purpose so I hope people are compensated, who work from home, have family arriving... nothing was in place for these drop outs and nothing is seemingly being done. Everyone, go to down detector so there is a registered issue and they have to do something about it. I cant even stay on live chat long enough before having to restart my router, there is no ping service when a response comes so you have to stay by the computer or phone incase you get a reply.... 3 hours later.
12 REPLIES 12
Message 1 of 13
Hi @Starlightbeebright
Sorry for the delay.
Is the connection still down this morning?
Message 2 of 13
So, it's just dropped. I haven't restarted the router, and I have to run an errand soon, so I have to go out and will be back around 5:30 p.m. I hope I'm not left again over the evening without some resolution.
Message 3 of 13
it just dropped
Message 4 of 13
Could you post back here as soon as the connection drops so I can pass it straight to the engineer to look at whilst the fault is present (please don't reboot the router)
Message 5 of 13
ok i have added those, after having to reset the router again after it dropped.
Message 6 of 13
Our engineers are investigating this issue and they have asked if you can try the below:
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
Message 7 of 13
Yes it stays on after i re set it.
Message 8 of 13
Can you check if the white light stays on the front of the router when the connection drops?
This maybe linked to a fault which our engineers are investigating.
Message 9 of 13
This is how bad your testers are, I cannot even write here properly, nor have I had any response on live chat. We all made you aware of this issue last week and then you left it over the weekend.
Message 10 of 13
Michelle, i have had now three people do this line test, all telling me that it is fine, it is not fine, it does not fix it consistently, every hour I have to re set. I was told that I would have a new router sent to me, then he changes his mind, then he left me hanging. The ctomer service over the weekend was appulaing, but yes Michelle, I have done EVERYTHING.
Message 11 of 13
I'm sorry for the delay in getting back to you. I've run a test on your line now just to make sure that there are no hard line faults detected and the line test is clear. Is the light on your router remaining white when the connection is dropping as this may be related to a fault that our Network Engineers are currently looking into?
Starlightbeebright
Message 12 of 13
i would like to show everyone what I have been dealing with today, if anyone knows of an ISP that is English please let me know. it got to the point where I'm sure they were just winding me up. Even when I showed them what was happening, and they kept saying they would send a new router then asking me if I wanted one and I would have to pay for it. This took 3 hours wait and then 1.5 hours for them to tell me there were no issues, whilst I was using my mobile data to even connect to them.
