on 11-12-2024 09:15 PM
Hi there
Recently I sing up with TalkTalk. For the first 2 months I haven’t got any problem with my broadband. However last week my WiFi keeps dropping out randomly during the day. I can’t even connect my phone to WiFi there no connection most of the time. I’ve spend hours over the chat. TalkTalk send me new router and ensure that now everything will work perfectly fine. Because the old router seems to be the faulty. I’ve connected my new router and WiFi its still dropping out. It’s start to be very annoying. I’m paying for my fibre 65 and TV hub that I can not use! I really want to book and engineer to come have a look at this but don’t know if there is any other form of contact then a chat
on 20-12-2024 07:52 AM
That's great news, thanks for letting us know
on 19-12-2024 09:14 PM
Hi @Anonymous
Thanks for all the help. Connection seems stable now. It doesn’t dropping or anything. Appreciate it.
on 18-12-2024 07:19 AM
Good morning,
Apologies for the delay in getting back to you. Update 8:40PM December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
on 16-12-2024 10:16 AM
Hi nikola,
I'm sorry for the delay. Our Network Team are currently investigating the white light/no connection issue and I will post back as soon as the team come back to me with an update.
on 15-12-2024 01:11 PM
Hi @nikola77
on 15-12-2024 10:05 AM
Hi @KeithFrench
I did perform reset of my router but connection it’s still dropping out.
on 14-12-2024 12:59 PM
Thanks for that information @nikola77. One way to perform a factory reset is to log into the router & go to:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Maintenance > Resets
Then click the Factory Reset button.
on 14-12-2024 12:47 PM
Hi @KeithFrench
I just checked and the first router I had was Sagemcom FAST5364 and they send me Sagemcom FAST5464. How to perform facotry reset? When I spoke over the chat before they send me new router they did factory reset, and that didn’t help. When I try to do reset my router it don’t let me don’t flash or anything.
on 14-12-2024 10:38 AM
Hi @nikola77
Which router do you have? From an earlier description of it having one white light, this narrows it down to one of three:-
You can tell by pulling out the "pull-up" panel on the top of the router & behind that is a label on the router itself, that contains this information.
If you have the Huawei, then this needs replacing anyway.
There is a bug in the firmware that affects either of the two Sagemcom routers. If you disable either WiFi band, it will not normally come back OK when re-enabled (despite the UI showing it as enabled again). The only workaround until this is fixed is to do a factory reset of the router.
on 14-12-2024 10:21 AM
Hi @KeithFrench
Yes I tried to switch between them switch off one band and leave another one on. However looks like when I leave 5GHz on I couldn’t connect at all to that band.
on 13-12-2024 09:43 AM
Hi @nikola77
You say that you have tried switching between the 2.4 & 5GHz bands, did you disable one of the WiFi bands within the router?
on 13-12-2024 09:35 AM
Thanks, we are looking into this, we'll let you know when we have an update
on 13-12-2024 09:33 AM
Hi Chris
The light stay steady white.
on 13-12-2024 08:51 AM
Hi nikola7,
When the connection drops does the router light stay white or does it change to orange?
on 12-12-2024 08:25 PM
I did it like you said and connection last for 2 hours straight without fail. However after 2 hours connection dropped and had to turn off router from the plug. the button on the back of the router seems dont work. will wait till tomorrow see what support team will says
on 12-12-2024 06:10 PM
OK, if you gently press the two clips on the side of the faceplate it will come off and you will see the test socket behind that. Connect to that and leave it there until you hear again from the support team tomorrow.
on 12-12-2024 06:08 PM
Hi there
I tried to switch between 2.4GHz and 5GHz and that didn’t help me either.
on 12-12-2024 06:06 PM
Here’s a picture of my socket. I come back home and I had connection for like 50mins and then dropped down.
on 12-12-2024 09:22 AM
on 12-12-2024 09:21 AM
Hi @nikola77
Thank you. I can then check if your master socket has a test socket. It's always worth testing the router at the test socket to rule out any internal wiring or faceplates faults before progressing to an engineer visit.
