poor wifi
damusk
Message 2 of 2
hi,
I feel like my wifi has been pretty poor for a while now. It mainly seems to be the 2.4 ghz channel. If i try to play online with my PS4 its basically unusable, Ive had to resort to using a powerline adapter. The router is ten years old now could it be on the way out? Any suggestions on something I could try to improve things?
thanks
1 REPLY 1
Message 1 of 2
I do see a lot of wifi errors at the router.  I'll get another router out to you and see if this helps.
Anonymous User
