Broadband Down - WiFi Hub Constantly disconnecting/reconnecting
Try a 30 minute reboot.
Wizz Kid
I have tried that twice and unfortunately it hasn't helped. Will give it a couple of days and see if speeds improves. Cheers
TalkTalk BorkBork
Since the engineer has been? Fair enough, but you should only do it once. One would have hoped that the engineer had reset DLM though, seems not.
Hi W130SN
Apologies for the delay.
I'm so glad to hear that the engineer was finally able to gain access and carry out work.
I've completed a line test which has detected a possible fault but your line is in sync at 73.9mb.
Is the router at the test socket? Have you tried running a speed test on a wired device?
Wizz Kid
RHxDLnT
https://www.talktalk.co.uk/help/servicestatus/track-fault
I am plugged into the test socket, if you could run a line test. Many thanks
TalkTalk BorkBork
Ran some line tests and the results are as follows :
NGA (Fibre test) : No Fault Found - sync at 73.9mb  (Up : 20mb) - NO RF Ingress, Bridgetap or REIN issues showing. - Overall assessment - No Service Impact Observed.
Meta  (Copper line) : Good line, 48V, Dialtone. - All voltages, resistance levels and carries all show as ok.
Tam :  passed - line tesk ok  IN and OUT.
Wizz Kid
Many thanks @OCE_Karl
TalkTalk BorkBork
No Problem 🙂
Wizz Kid
AFAIK the fault has been fixed but the following page is still showing a problem:
LM7ZFVM
TalkTalk BorkBork
If a fault is still open pending monitoring, this can be reflected in the service centre.
Wizz Kid
Lost Internet connection just before midnight last night.
This morning I received this:
JzxOy5i
Could you run a line test and give me the results, please?
TalkTalk BorkBork
Line tests are currently clear but it is flagging up that thee is planned maintenance that may affect your circuit.
Wizz Kid
Thanks for the reply @OCE_Karl
TalkTalk BorkBork
No Problem 🙂
Wizz Kid
https://www.speedtest.net/results?sh=b7a9772e76e09353062901ddff29fdb7
TRM4stD
Please could you run a line test as speeds seem to be slow atm
NdeEFvT
TalkTalk BorkBork
Hi W130SN,
I'll take a look now. I've run a test on the line which hasn't detected a fault and the sync speed and profile both look ok. Is this a wired or wireless speed test? Is there any improvement if you switch the router off for a full 30 minutes?
