Constantly restarting router. Faster fibre to cabinet.
14 REPLIES 14
Wizz Kid
For some weeks my router has been restarting at least twice a day and sometimes three or more during an hour. Sync speeds can vary between 20.1Mbps and 13Mbps. This plays havoc with watching streamed channels.
All suggested fixes carried out and when I have physically switched the router off the reconnecting speed is around the 20.1Mbps.
i had major problem several months ago when Openreach messed up connections in a box and speeds never been same since.
All usual tests are clear, no line issues showing.
I'll swap out the router so we can rule out a hardware issue.
Wizz Kid
Thank you Karl.
My Sagemcom Fast 5364 is loosing its settings, I set a port forward for 3389 (remote desktop) and changed my wifi name from the default 'TalkTalk ......' to a custom name. After about a week my port forward setting suddenly vanished!
Then about a week later my custom name for my wifi access (AP) reset it self back to the default name again.
This all happened after the 5364 had been resetting itself, it would power down and restart, flashing amber light then white, then restart again, flashing amber light then white, then I couldn't connect to it.
I thought it was the line so did a web test through the TalkTalk support page, all was ok, then I realized that my custom names were not showing when I was trying to reconnect to the wifi, and that the default names were now showing again !
Does anybody know why this is happening, do I have a faulty 5364 ?
I don't want this to keep happening as I am away from home a lot and use my remote access to my devices at home. I would not be able to access this if trying to connect remotely.
All was working fine when I originally set it up, so there's no problems with the configuration of these settings.
No Problem 🙂
When the new router arrives, use all the new cables also, and let me know if it helps.
Hi @Stormer
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Wizz Kid
Hi Karl,
router received and set up at 3:00pm today. Will monitor performance and advise of any problems or confirm solution.
There is no return bag enclosed with the router for return of unwanted router. Can you advise?
Many thanks for your prompt action.
songbird1949
Hi songbird1949, I've ordered a returns bag for you.
Ady
Wizz Kid
Replacement router has not resolved the problem. Yesterday 13-2-2020 my router was disconnected 5 times, (4 between 5:30pm and 11:30pm).
This problem of disconnecting has been noted by the system/line checker for some time.
please advise as all avenues here have been explored. It seems to me that the line maintenance system is causing the problem.
Wizz Kid
Should have added this to my post. My sync speed at the router dropped every time there was a disconnection from 20.9Mbps at 12noon to 16.8Mbps at 11:30pm. This is no where near what I expect to be receiving
The estimated speed of the line is 13-22mb so with the current sync speed of 19mb, the speed of the line is correct.
I am seeing a couple of retrains and have made a change here.  Can you see if stability improves over next 24hrs.
Wizz Kid
Thanks for the information Karl.
My main concern is the number of times I am loosing connection.
On Saturday I lost connection a further 5 times between 6:58pm and midnight. (6:58, 7:11, 8:06,11:34, 12:00midnight)
This is playing havoc with recordings on my YouView box, having half or partially recorded programs.
Stability of the connection is what I need.
If the change I have made shows no improvement then we will need to arrange an engineer for you.
Wizz Kid
Thanks Karl.
Will continue to monitor the connection and report to you either success or failure in a few days. Weekends do seem to be a more problematic time so may wait until after next weekend.
Hi songbird1949
Thank you, please let us know how you get on.
